Pdiggs's avatar
Pdiggs
ORBI RBS850 Blinking White and will not connect to RBR850 Router
Please Help. I had both satelites working fine and now 1 satelite will not connect. It just blinks white. I have factory reset to blinking amber and it still blinks white. I've tried to hardwire my laptop to the satelite and can't get an IP to update firmware. This is only a month old- please provide feedback or it's getting returned! Thanks
  • FURRYe38's avatar
    What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
    Wire connect 1 PC to the back of the RBS.Press the reset button for 15 seconds then release. and wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
    IF this fails then you'll need to get the RBS replaced.
    • Pdiggs's avatar
      Pdiggs
      Thanks I tried to follow this. But it's confusing- what is the point of connecting to the first Satellite and then to the dead one?
      • FURRYe38's avatar
        Sorry I should have not mentioned the 1st satellite, rather, Connec to the one satellite giving you problems.
