rhettarded
Dec 06, 2022Aspirant
Orbi RBS850 (with satellite) keeps disconnecting Wi-Fi Computers
Hello folks, I'm having persisting problems of my orbi wifi disconnecting my laptops. I know it's only laptops since our phones are fine, and I say it's the orbi wifi because my wi-fi connection in s...
rhettarded
As Kevin suggested, it is now on AP mode, and orbi router has a new IP address 192.168.1.163
Does a message appear on the laptop?
-no, it disconnects on its own
Does the laptop reconnect automatically?
-no, I have to manually reconnect to the network(please see link of video is my last reply)
Does anything appear in the Orbi log at the time a laptop disconnects?
-i will have to check it
What do you do to get the laptops connected again?
-i have to manually reconnect again, and to make it stable, my option is to only reconnect via ethernet which defeats the portability of a laptop.
CrimpOn
Dec 06, 2022Guru - Experienced User
Thanks (sometimes posts "cross in the mail" while we are typing).
Is there any significance to the name "VPN Unlimited"?
- rhettardedDec 06, 2022AspirantYes, I have VPN Unlimited installed in my PC and one thinkpad. I doubt that is the culprit as I need to sign in and connect to be able to access a VPN. My other thinkpad that doesn't have it, but has the disconnecting issue. Also, this disconnects only on my home network, never in school or public places.
- KevinLiTDec 06, 2022NETGEAR Moderator
Hello rhettarded ,
Try forgetting your home network and when you reconnect to it select public network.
CrimpOn Has a point with the VPN. It showed as no internet. That can mean that it is active with no connection Please ensure that it is disabled.
Best,
Kevin
Community Team
- CrimpOnDec 06, 2022Guru - Experienced User
Wonder what happens if the laptop attempts to open the regular WiFi adapter, rather than the VPN adapter?
