bensjb0618's avatar
bensjb0618
Follower
May 02, 2023
Orbi Robust Smart Home Wi-Fi Tri-band Mesh Wi-Fi 6 System will not connect to provider’s modem
Will not connect to provider’s modem
1 Reply
  • FURRYe38's avatar
    Not much to go off of.
    What Orbi system model do you have?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
