Darrelltate's avatar
Darrelltate
Orbi satellite daisy chain via switch
Wondering if I can connect two orbi satellites via Ethernet through a switch.
1st satellite is connected via wifi to router.
This satellite is connected to a switch via Ethernet.
Wondering if I can connect a second satellite to the same switch, rather than Wi-Fi, to increase speed and strength of signal.
thank you for any feedback you can provide.
darrell
  • Yes, that is exactly how mine is set up.   2 x wired, 1 x wireless.   Just make sure your switch is not "green"
