Newt8456
Jun 26, 2024Follower
Orbi Satellite RBS850
Hello, we have had the Orbi Satellite RBS850 in my house for about two years now and until recently it has worked great. Two weeks ago the Orbi started acting up, back then it was nothing simply shutting wifi on and off on your phone would fix. However last week until it started acting very weird. We have Fidium WiFi.
The WiFi is very spotty. It will go from working just fine then drop the network for 2-3 minutes. The WiFi won't disconnect from the device, just show "No connections, secured". It'll come back for maybe 5 minutes then the Orbi will turn pink/magenta either solid or flashing light. When this happens the WiFi will just stop, it glows pink and does nothing. We've reset it, turned it off and on, unplugged the router, unplugged everything for 10 minutes and no matter what this problem keeps coming back. Everything's updated, security is fine, there is no problem. We contacted support via phone call and the support lady said she needed to "Clear some errors, then reset your wifi and it should work". As someone works in the customer service industry in my family I was told this is EXACTLY what they say when there is no problem and they just need to say something.
Someone please help, this has been going on for WEEKS with no solution.
1 Reply
What Firmware version is currently loaded on the RBR and RBS?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does swapping RBS locations with another follow the problem or remains at same location?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
