mrcrowbar's avatar
mrcrowbar
orbi satellites connecting to each other vs router
I have the orbi wifi 6 router with 2 satellites.  My router is on main floor, 1 satellite upstairs, and other satellite in basement.  My basement satellite is connecting to my upstairs satellite instead of the main floor router, which is a problem since they are 2 floors apart and I am experiencing poor backhaul on the basement satellite.  Any recomendations?
  • I switched them, moved the basement one upstairs and up one down to basement.  For whatever reason, this seems to have solved the issue, no clue why?  Thanks all.
    • mrcrowbar's avatar
      mrcrowbar
      9Kish+ sq/ft.  So I think each floor is 3K give or take.  No crazy building materials I know of, built in US in I believe '09, so somewhat new.
      Hard to tell exactly how far apart they are but I have them each as close to the middle of the floor they are on as I can get, and stairwells are somewhat centered on house as well so I assume that would remove some of the signal loss.  If it is 30ft in a straight line, I am confident I am within bounds there.  So that's what it is so odd the basement sat would connect to the top floor sat, that's definately more than 30ft away, the main router is meaningfully closer.
      • FURRYe38's avatar
        Guru
        Like Plemans mentioned, seems like placement and possible how you have them placed is causing them to Daisy Chain instead of configure in Start formation.
        Try moving them farther appart and try turning them OFF and back on in sequence. I usually start with the farthest RBS first, then turn on the closer RBS lastly.
  • I'd also try  moving the satellites/router around.
    Many times hvac is ran within the floors/ceiling. And hvac is great at blocking wifi.
    Try shutting off the router and the satellites. Then move the satellites around. (laterally)
    then boot the router up and then the satellites back up.
