envirotecky's avatar
envirotecky
Follower
Jan 29, 2020
Orbi satellites not connecting
Im ready to chuck it out the window.  We had a disruption thru internet provider. When it came back up the Orbi would not work.  My internet provider, Spectrum, has disruptions in service frequently here.  If I have to go thru tthis evry time, its not worth the trouble to me to spend hours trying to reconnect the Mesh network.  I have tried resetting everything and finally got the Orbi router to connect.  But satellites will not. suggestions???
  • You said Satellites.... can you tell us how many you have and how they are connected (wired or 5G RF backhaul)?
    If wired, is there a switch between the RBR and RBS?
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    The RBS should auto sync to the RBR if there is a power loss. They should remain connected to the RBR if the RBR looses connection to the ISP modem...
