PanchoB
Mar 22, 2022Follower
Orbi speed issue
My setup now has the RBR750 router, directly off my Comcast modem. I have 3 satellites throughout the house, one of which is hardwired via CAT-5 to the main router. Off the satellite, I have a Cat-5 to a switch, and my AppleTV, smart TV, and PS4, all hardliners. When everything is fresh off a restart, I get the full speed(approx 800mbs) at the hardwired satellite. After a few days, that drops down to maybe 100mbs, on a good day. Why does it go full blast at first, then start dropping off?
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Is the one RBS directly connected via ethernet to the back of the RBR or is there a LAN switch or wall outlet in between?
For ethernet cabling CAT 6 is recommended. CAT5 only supports 100Mpbs and would be limiting on wired performances.
