Yuowin
Jan 02, 2025Aspirant
Orbi system appears to be rebooting every night around the same time
Hello community. We are using the Netgear Orbi RBR750 system. Every night around the same time. ~11:35pm our system seems to reboot. All our devices lose WiFi connection. Looking at the LED’s on th...
Yuowin
Jan 04, 2025Aspirant
I will try downgrading. I checked and it is a 24 hour lease. WiFi went out at 11, router stats show system uptime a minute after WiFi went out so it’s definitely rebooting. Ugh. Hopefully the downgrade helps!
Thank you
Yuowin
Jan 09, 2025Aspirant
Sadly it is still rebooting. Speaking to family members it's been happening multiple times a day but I just only noticed it at night. Perhaps it's a defective router I don't know at this point, but I'm buying a different router and hooking it up and will see what happens.
- FURRYe38Jan 10, 2025Guru - Experienced User
Does this happen with RBS turned OFF?
Does the front LED on the RBR and RBS turn PINK or blink WHITE when this happens?
Did you factory reset the system after downgrading back to v.21 and make sure you disabled the auto update function on the RBR?
From the CM modem, Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.- YuowinJan 11, 2025Aspirant
Hello,
I have not tried turning off the satellites as part of the house needs it to get signal but I can attempt that.
When it occurs the RBR and RBS units are blinking white.
I did not factory reset after downgrading so I can do that tonight, but I did disable the auto update feature.
Here is the modem connection status
Hardware Version 2.02 Firmware Version V6.01.07 Cable Modem Serial Number 67H10CWYA1F4A CM certificate Installed CM MAC 94:a6:7e:0a:e7:ec I will attach the event log file.
I was reading about the ethernet cable and I did have an old cheapie 5a, so I upgraded to this 6 cable from amazon but it does not have STP as you listed.
I ordered : https://a.co/d/09NNK6S
Should I exchange it for something like this ? https://a.co/d/4U5X7aF
Thank you for your continued help!
- FURRYe38Jan 12, 2025Guru - Experienced User
Please capture the cable connections log data page as well for reivew.
Event log look good.
Yes if you downgraded, a Factory Reset is required.
