mooney21
Apr 30, 2020Aspirant
Orbi Top Talker
There is no more possibilities to check, for each device connected, the bandwidth consumption - in real time - (as we did in previous Netgear routers / WIFI). For me it's a huge weakness for a syste...
Apr 30, 2020Guru - Experienced User
Seems that Orbi since AC doesn't support this at all. Something you can post about here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Orbi seems to be tuned to the average home user and not more advanced users. The system seems tuned to running as automatic and with out any user configurations settings as possible.
For the most part Orbi supports having lots of devices connected. It works since the RBS are also picking up bandwidth handling abilities and helping share the load of many connected devices. I've seen others with 50+ devices post having good experiences with Orbi systems.
If Orbi isn't something tuned for your liking, then you might find a router that does and use the Orbi in AP mode to take advantage of the wifi MESH system. You can connect Orbi to any router.
kildare
Apr 30, 2020Luminary
However using a router and the Orbi in AP mode couldn't solve the problem of mooney21
as he needs to check the bandwidth consumption for each connected device...
FURRYe38 wrote:If Orbi isn't something tuned for your liking, then you might find a router that does and use the Orbi in AP mode to take advantage of the wifi MESH system. You can connect Orbi to any router.
- FURRYe38Apr 30, 2020Guru - Experienced User
That maybe handled by what ever router he gets that can check each device. The Orbi in AP mode is just mostly pass thru traffic to the up stream router.
- kildareMay 01, 2020Luminary
Honestly, in my 25-years work as a computer engineer, I've never found a WAN router of the consumer/prosumer/small business class that was able to calculate and show the bandwidth occupation (transfer rate) of the single devices connected to an access point, but only statistics calculated on its ports basis (LAN or WAN), and I've used and configured routers from very many manufacturers (Cisco, Linksys, Asus, Netgear, D-Link, Zyxel, Tp-Link, DrayTek, Huawei, ...).
Nonetheless such a router might exist, but would be very hard to find…
Anyway, what @mooney21 is looking for is probably something like what the Asus ZenWiFi AX provides, as can be seen in the attached image.
- FURRYe38May 01, 2020Guru - Experienced User
Agreed.
Been working with routers and such for a while now as well. Asus seems to be the best or have more of what the OP is looking for if thats what they need.
Good Luck.
