Nayef1
Apr 01, 2023Aspirant
Orbi Wi-Fi xfinity issue
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think som...
Apr 01, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Nayef1Apr 01, 2023AspirantXfinity modem is XB7
4.6.14.3 firmware- FURRYe38Apr 02, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
4.6.14.3 firmware - bullm00nApr 28, 2023Virtuoso
4.6.14.3 firmwareWe're using the same Xfinity Modem. I have the Orbi in AP mode for a good while that has worked well. I'm planning to try it with the XFi Gateway in Bridge mode soon with Orbi as Router. I think Orbi's Reserved IP /DHCP management works a little better.
