Nayef1
Apr 01, 2023Aspirant
Orbi Wi-Fi xfinity issue
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think som...
CrimpOn
Apr 01, 2023Guru - Experienced User
Nayef1 wrote:
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think something went wrong with my Wi-Fi specifically.
Some additional detail would be helpful:
- Which Speed Test is showing the expected speed?
- A Speed Test report from the Orbi router web interface or the Orbi 'app'?
- A Speed Test run on a device wired to the Orbi? (Such as Ookla Speed Test)
- A Speed Test run on a device connected to Orbi over WiFi?
- If the Speed Test was a report from the Orbi, then it would be very helpful to use a web browser to connect to Ookla Speed Test and measure speed from both a wired and WiFi device. https://www.speedtest.net
- In what way are apps like Twitter and YouTube not working when connected over WiFi?
- What sort of devices is this happening with? (more than one?)
- Is it safe to assume that everything was 'normal' until just recently?
