Nayef1
Apr 01, 2023Aspirant
Orbi Wi-Fi xfinity issue
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think som...
CrimpOn
Apr 01, 2023Guru - Experienced User
Nayef1 wrote:
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think something went wrong with my Wi-Fi specifically.
Some additional detail would be helpful:
- Which Speed Test is showing the expected speed?
- A Speed Test report from the Orbi router web interface or the Orbi 'app'?
- A Speed Test run on a device wired to the Orbi? (Such as Ookla Speed Test)
- A Speed Test run on a device connected to Orbi over WiFi?
- If the Speed Test was a report from the Orbi, then it would be very helpful to use a web browser to connect to Ookla Speed Test and measure speed from both a wired and WiFi device. https://www.speedtest.net
- In what way are apps like Twitter and YouTube not working when connected over WiFi?
- What sort of devices is this happening with? (more than one?)
- Is it safe to assume that everything was 'normal' until just recently?
Nayef1
Apr 02, 2023Aspirant
Speedtest over wifi on iPhone and MacBook. Just started happening recently.
Either it opens tweets, videos and webpages very slowky or won’t load them at all.
Wired speeds and Wi-Fi speedtests are consistent.
