Dustin_V
Sep 06, 2019NETGEAR Employee Retired
Orbi WiFi 6 at IFA 2019 - 2nd Gen Mesh WiFi Is Here!
Announced at IFA 2019 in Berlin, NETGEAR Orbi WiFi 6 Ultra-Performance Whole Home Mesh WiFi System is the next evolution in Mesh WiFi. As the only Tri-Band WiFi System built with the latest and fastest WiFi 6 technology, the latest Orbi WiFi System is designed to provide the ultimate smart home experience with WiFi and connection capacity.
Orbi’s award-winning technology provides the ultimate in WiFi coverage and speed, giving you better WiFi throughout your home. Using the latest WiFi standard, this WiFi 6 edition of Orbi will benefit homes looking for strong WiFi connections in every room, all the time. WiFi 6 technology will upgrade your experience by providing enough bandwidth for your automated smart home and all of its devices. With 4X increased capacity and improved performance, this means you will be able to have multiple 4K/8K UHD streams and online gaming without any interruptions.
For the home with a Gigabit Internet service plan, it gets even better. Orbi WiFi 6 will provide blazing fast WiFi speeds to all of your devices, giving you Gigabit speeds all throughout your home. Also, with more available WiFi streams, your network will have more available bandwidth and less congestion.
To learn more about the latest addition to the Orbi WiFi Family, please click here.
- TNMEMInitiate
$699.99?!!?!!
- computersteveApprentice
For that price it should sing a song when I power it up !!! No but seriously only two devices for $700.... I mean it should have at least two satelites or an outdoor orbi included at that ridiculous price.
- tagteamVirtuoso
Costco still sells the RBK53 (router plus 2 satellites) for $400. That seems like a bargain compared to $700 for a router and one satellite with, seemingly, the ONLY difference being WiFi 6 which is useless without client devices that support it (and of which I own ZERO).
- KnitmanAspirant
It costs thwe same in GBP here which is a ripo off. I have noticxed many companioes do this. Not giving UK custmers the echange rate price but just changing the currency ands not the figure,
I got an email from NG marketing today saying there 7 series Orbi AX is going for $450.
A bit confused after I read specs on the product page. Seems like it has slower link speek on 5GHz backhaul in between the router and the satelite (1,200Mbps) compare to what RBK50 has (1,733Mbps). I wonder how this would affect the total stability and bandwidth of the backhaul
- ekhalilMaster
theBrick89 wrote:A bit confused after I read specs on the product page. Seems like it has slower link speek on 5GHz backhaul in between the router and the satelite (1,200Mbps) compare to what RBK50 has (1,733Mbps). I wonder how this would affect the total stability and bandwidth of the backhaul
The wireless backhaul in RBK852 is 2.4 Gbps (4x4:4 / 80MHz 802.11ax) compared to 1.73 Gbps in the RBK50.
Will it be possible to use the existing RBS50Y outdoor satellite with the new WiFi 6 system? I understand that any non-6 satellite wouldn't offer Wi-Fi 6 speeds. In other words, will be possible to mix nodes from the current generation and this new one?
- TOK2000Aspirant
When will Netgear have Wifi 6 USB adapters to match all the new Wifi 6 routers/Orbi?
When they become available. NG doesn't post when new stuff hits until they are ready. Keep an eye on there product pages.
What's the difference between the AX5700 and AX6000?
- GazaJimboInitiate
When will the Orbi WiFi 6 system become available in Australia?
Though, given the US pricing, I think Netgear will be directing WiFi 6 customers to the opposition. FYI: I got the AX6000 (RBK850) and am unable to connect an RBS50 to it. I spoke w/Netgear customer service. They tell me that currently the RBS50 can't be connected to an RBK850, but that engineering hopes this will be possible in the future. No estimated date currently.
Yes, this is known already. Some have connected RBS50s via ethernet and they work then. Just not wirelessly. NG says future FW updates should make them wirelessly compatible. Keep an eye out on release notes.
- Chuck_MMentor
Itwindansea wrote:FYI: I got the AX6000 (RBK850) and am unable to connect an RBS50 to it. I spoke w/Netgear customer service. They tell me that currently the RBS50 can't be connected to an RBK850, but that engineering hopes this will be possible in the future. No estimated date currently.
It CAN connect to RBS-50 if you have it wired directly via ethernet to the RBR850. I use two of them until the single RBS850s are available 01 March.
The RBS50s do not have AX functionality in any case.
- CgeorgiaAspirant
Can a Linksys Max Stream range extender Model RE 9000 connect to an Orbi 6 being used as a router?
- 4GadgetmanAspirant
Does this have WPA3 or will there be a FW upgrade to add this in the future?
Yes, WPA3 is supported. However not in Mixed mode, i.e. WPA2/WPA3. There are known problems with this. WPA devs have to fix this.
4Gadgetman wrote:Does this have WPA3 or will there be a FW upgrade to add this in the future?
