beansontoast
Jun 06, 2022Aspirant
Orbi Wifi 6 RBK353 - port forwarding turns off after a few days
Hello!
I'm on firmware V4.4.0.10_2.10.63.
I've set up fairly standard port forwarding. It works when I first set it up, but then after a few days - it stops working. I can go in to the settings again, and it is still listed - but it is not working.
If I delete it, and re-add it, it starts working again... but obviously this is not ideal, because I have to keep deleting & re-adding the settings every time it stops working.
Any idea why it might stop working?
The local host for portforwarding has its IP reserved in DHCP, so the IP address is not changing. Nothing is changing, it just stops working - I put the settings back in exactly the same & it starts working again.
Have you set up IP address reservations for the devices your using in the PF configuration?
Did you disable uPnP before setting up the PF configuration?
- beansontoastAspirant
hello!
Thanks for your quick reply.
The router just connects straight to the little Openreach Fibre thing, which doesn't seem to have a manufacturer or model number on it - it's just a wall mounted box, about 8cm x 8cm that says "Openreach" - connected by Ethernet to the Orbi router... & then has the fibre cable to the internet coming out of it on the other side. Worked with my previous 2 routers doing port forwarding absolutely fine, though.
Yes - IP reservations are set .
No - haven't turned off uPnP. Does Orbi only support Port Forwarding with uPnP turned off?
Most routers need uPnP disabled if you set a manual PF configuration. Something to try.
