TIJIM's avatar
TIJIM
ORBI WIFI 6
I have a ORBI WIFI-6 model G3100 (master and one satellite.  If I want to extend coverage can I just buy one more satellite and add it to the system.  If so is there one you would recommend?
  • FURRYe38's avatar
    What model is the Orbi RBK3##, 7## or 8##?
    G3100 is not a NG model # for Orbi.
    • plemans's avatar
      G3100 is a verizon router. Are you sure you have an orbi setup?
      Of is the G3100 the gateay the orbi is connected to?
    • TIJIM's avatar
      TIJIM
      Apologies.  I did give the model number for the verizon router to which the ORBI router is linked.  The Orbi Router and Satellite are RBR50v2.  Can I just add another Sattelite to extend the coverage.
      • FURRYe38's avatar
        Yes.
        RBS20, RBW30, RBS40v or RBS50 will work. EX7500, 7700 or 8000 will work in a pinch but not integrate like RBS do.
        Orbi AX RBS will not work with Orbi AC systems.
        Will move this thread to the Orbi AC forum.
        Good Luck.
