Superlub
Mar 09, 2022Follower
Orbi Wifi connection dropping
HI, I DON'T have a problem with WiFi connection dropping on my Orbi RBK853...... anymore...:-) What happend? I bought the RBK853 system 18 months ago. Since installation I was experiencing p...
- Mar 09, 2022
Glad you got it working well.
I'd make a backup of your system while its running well :)
And you might want to mark it solved. that keeps others from trying to fix it as well as those with issues might find that you got it fixed and what worked.
good work!
Mar 09, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Glad you got it working.Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
