Superlub's avatar
Superlub
Follower
Mar 09, 2022
Orbi Wifi connection dropping
HI,   I DON'T have a problem with WiFi connection dropping on my Orbi RBK853...... anymore...:-)   What happend? I bought the RBK853 system 18 months ago. Since installation I was experiencing p...
  • plemans's avatar
    Mar 09, 2022
    Glad you got it working well.
    I'd make a backup of your system while its running well :)
    And you might want to mark it solved. that keeps others from trying to fix it as well as those with issues might find that you got it fixed and what worked.
    good work!
