OrbiEd
Jul 10, 2021Aspirant
ORBI wifi not visible
ORBI RBR750, Just purchased orbi RBR750 with one satellite but can't set up on phone app as the orbi wifi is not visible on any device in house. Model # not available in field above, 2nd forum to post? Is this correct area
Try a different wifi device and Orbi app?
Try setting up the RBR and RBS with a wired PC or laptop connected to the RBR and web browser pointed to 192.168.1.1
- OrbiEdAspirantThe WiFi I am trying to see is the Orbi wifi, so if not visible on huawei phone, iPhone, Samsung phone and IBM laptop, I suspect the issue is the Orbi and using a different app will still have the step, connect to the orbi wifi.
I could try connecting the orbi to the pc but this does not follow the netgear instructions and I would not be fully confident on what settings I would need to be setting.- FURRYe38Guru - Experienced User
You would follow what is seen in the setup wizard that will help you out in regards as to what you'll be doing.
