hmvm12345
Jan 27, 2024Tutor
Orbi6 Intermittent Performance Degradation
I've had an Orbi 6 system (router + 2 satellites) for almost 2 years now. Worked like a charm until about 2 months ago. Since then at times, I can see painfully slow connectivity on my laptop, connec...
Jan 27, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
You behind on FW as well:
- hmvm12345Jan 27, 2024Tutor
Thanks a lot, I'm going to work through a few of these. The FW part surprised me, but now I'm going through the manual upgrade process. Btw, I don't know if you have the ability to do this, but it'd be great if Netgear updated the instructions for the manual upgrade. Most of it just seems to be 'download file, upload and install', but the file you download is a zip and it's rejected by the UI without much of a message. Somewhere else I read that the system is expected a .chk file, so that made me unzip and I'm now successful.
- FURRYe38Jan 27, 2024Guru - Experienced User
I'm planning on asking NG to update there KBs with what I posted here in the forums that gives better details and explanation of how to do a manual update. Glad it helped.
I'm now on the newest firmware on all 3 devices.
I'm going to do another power reset as you've suggested.
House profile: urban rowhouse, 4 floors. Satellites in basement and 1st floor. Router on 2nd. ~3500 sq ft total. Orbilogin shows Backhaul status as 'Good'.
Enable AX is on for 2.4, 5 GHz. Both 2.4,5 are enabled. Channel frequency for 2.4 is auto, 5 is pinned to 36 (my tinkering).
Additional features are off.
Do you have a good test to suggest I run between these debug stages?
- hmvm12345Jan 29, 2024Tutor
NG Router is connected to a Verizon branded modem. I've disabled wifi on the VZ gear, so I'll have to login later via a cable to figure out other details, not many markings on the box itself.
I should note that my wife is on the wifi (connected to the RBR) and sees no issues whatsoever.
I just did a factory reset on the RBS near me and have now attached it back to the network. Still experiencing network issues. My morning zooms really sucked and Cloudflare speed test is giving me a Poor rating for Video chatting.
- FURRYe38Jan 29, 2024Guru - Experienced User
Does the wife's PC or devices get same rating for video test quality?
is SIP ALG enabled or disabled under Advanced tab/Setup/WAN setup?
Where you able to get the system FW updated yet?
I put this up for details on how to manual update FW on Orbi systems:
Does the wife's PC or devices get same rating for video test quality? <- I'm getting Average/Average/Poor for Video Streaming/Gaming/Chatting on Cloudflare's speed test. She's getting Great/Great/Great. My latency and jitter are off by 2 orders of magnitude relative to hers. To be clear, she's using wireless too, just connected to the RBR.
is SIP ALG enabled or disabled under Advanced tab/Setup/WAN setup? <- Enabled ie. I haven't checked the 'Disable' box. This is default.
Where you able to get the system FW updated yet? <- Yes, all on V7.2.6.21_5.0.20
- FURRYe38Jan 30, 2024Guru - Experienced User
Can you take a picture of this Verizon modem and also see if there is any stickers on the side or under this modem that may have a product model #?
If this modem has wifi, then it most likely has a built in router as well. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- hmvm12345Jan 30, 2024Tutor
Okay, I've disabled all radio from the VZ device. I had the wifi off on all frequencies already ... have now gone into radio management.
I'm trying to fix the double-NAT but it's not totally obvious how to get this thing into a bridge mode of some kind. The OEM is well hidden and the only model identifier I'm seeing is CR1000A. User guide is here
