hawii
Mar 04, 2026Aspirant
ORBI853 wired backhaul speed stuck at 400M, wireless backhaul is normal
My ORBI 853 device is a product from China. I used nmrpflash to downgrade it to the lowest version, 3.1.5.23, enabled telnet, then navigated to the "bin" directory, executed "burnsku 0×0002," reboote...
CrimpOn
Mar 04, 2026Guru - Experienced User
Thanks for the quick response. So, after enabling telnet in order to change the Region setting, updating firmware to current versions disables telnet again?
- hawiiMar 04, 2026Aspirant
The answer is yes, upgrading to the new firmware will automatically disable telnet, unless you downgrade to the factory firmware again.
