Macktruck24
Jun 12, 2023Aspirant
ORBI960 on Starlink
Sad day today. I have Orbi 960 in 2 of my locations. I spent 3 days between NETGEAR and starlink trying to get them to work. They just don’t work together. I bought Eeros just to test and it worked in...
Jun 12, 2023Guru - Experienced User
Did you put a GB LAN non managed switch in between?
- Macktruck24Jun 12, 2023Aspirant
Yes - the starlink person that helped tested it. It brought up one web page then shut down.
- FURRYe38Jun 12, 2023Guru - Experienced User
What do you mean by shut down?
Others seem to have been able to get theres going.
Not sure why yours wouldn't.
What was the brand and model # of the switch being used.What was the CAT# of the LAN cable used in between the RBR and switch and modem? CAT6A STP is recommended.
Theres been lot of issues with Starlink. Seems to be related to there services and how they connect with some external wifi systems.
It would not open another web page. Just said internet connection not available. I had a netgear level 2 support person on the phone, and after 3 hours he said I need to work with Starlink.
