jfdorbi
Jan 04, 2021Tutor
orbilogin.com does NOT ask for username/password at login
While the ios app asks for an admin u/p at login, the orbilogin.com site does not. Seems like it should. Is this normal behavior?
I have gone through the set password function on the web interface, but logged out and back in and it still did not ask for credentials. Any other ideas on how to force it to do so?
Thanks
After a factory reset and reinitialization, the u/p login prompt now shows up at orbilogin.com and the orbi app.
Again, thanks for all suggestions.
- ekhalilMasterClick on “Logout” on the upper right corner in the web GUI to logout so you’ll be then asked to enter user name and password to login again.
Be sure to clear out the browser cache as well.
- jfdorbiTutor
Thanks for these suggestions, I have tried both multiple times. Also rebooted the router and tried again, but the obrilogin.com page just allows you right in to the administration gui without prompting for credentials.
As for the browser cache, it allowed me right in the first time I attempted a login, so it wouldn't appear to be that.
I have scoured all of the settings areas for one that seems like it would make the webservice wide open like this but can't find one. Am I missing it?
Again, the ios app asks for the u/p at login like you would expect. I really don't like that this one does not...
Thanks for any additional ideas to try.
