MVS2025
Jun 04, 2025Aspirant
Outdoor wifi access point needed compatible with existing indoor RBR750
I currently have the Orbi 750 (I believe it's the RBR750) wifi 6 system with 1 router and 2 satellites throughout my house. It works pretty well but we need to get a stronger signal in our backyard ...
MVS2025
I have many windows in the back of my house that I could setup an extender but would prefer to connect to an outdoor AP to make sure the signal is strong out there. Probably need to extend 100-150 feet at most from the house to cover most of the entertaining area and pool. Could I simply connect the WAX610Y to one of my existing satellites (not the router) and run to the AP outdoors? Getting the cable out there could be a challenge but I'm already having a contractor punch out some audio cables for our future sound system so could run it that way.
- FURRYe38Jun 04, 2025Guru - Experienced User
Ya that should work, Ethernet from closest RBS out to the WAX AP. If your going to run LAN cable, recommend CAT6A STP at least.
