garrettbagby
Sep 14, 2025Follower
Packet delay spikes at regular intervals
Hello, I would like to start this stuff and am going to information dump a lot of what I've attempted.
To begin, I've noticed since a few months ago ive begun to get debilitating jitter in the games ive played and finally started to look into it.
I have an an Orbi RBR750 router with 2 separate RBS750 satellites. One is placed upstairs and another (the one I'm connected to by ethernet) is placed roughly 60 feet away in a separate room. The satellite i am wired to is also wired to a SmartThings hub and the Orbi router is connected to a TP-Link TL-SG108 8-port gigabit desktop switch.
Connected to the satellite, I see 20% packet delay with 0% packet loss and when connected directly to the switch i see no packet loss or packet delay. When i connect the satellite directly to the switch i also see no packet loss or packet delay. I will say that pingplotter states im losing 95% of packets but i dont believe that to be true.
These are a breakdown of the tests ive tried thus far.
Ping Plotter to valve servers:
Ping directly to my router:
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=103ms TTL=64
Reply from 192.168.1.1: bytes=32 time=111ms TTL=64
Reply from 192.168.1.1: bytes=32 time=139ms TTL=64
Reply from 192.168.1.1: bytes=32 time=104ms TTL=64
Reply from 192.168.1.1: bytes=32 time=116ms TTL=64
Reply from 192.168.1.1: bytes=32 time=130ms TTL=64
Reply from 192.168.1.1: bytes=32 time=96ms TTL=64
Reply from 192.168.1.1: bytes=32 time=87ms TTL=64
Reply from 192.168.1.1: bytes=32 time=77ms TTL=64
Reply from 192.168.1.1: bytes=32 time=67ms TTL=64
Reply from 192.168.1.1: bytes=32 time=57ms TTL=64
Reply from 192.168.1.1: bytes=32 time=36ms TTL=64
Reply from 192.168.1.1: bytes=32 time=39ms TTL=64
Reply from 192.168.1.1: bytes=32 time=23ms TTL=64
Reply from 192.168.1.1: bytes=32 time=20ms TTL=64
Reply from 192.168.1.1: bytes=32 time=28ms TTL=64
Reply from 192.168.1.1: bytes=32 time=22ms TTL=64
Reply from 192.168.1.1: bytes=32 time=33ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=8ms TTL=64
Reply from 192.168.1.1: bytes=32 time=15ms TTL=64
Reply from 192.168.1.1: bytes=32 time=30ms TTL=64
Reply from 192.168.1.1: bytes=32 time=21ms TTL=64
Reply from 192.168.1.1: bytes=32 time=35ms TTL=64
Reply from 192.168.1.1: bytes=32 time=7ms TTL=64
Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Reply from 192.168.1.1: bytes=32 time=11ms TTL=64
Reply from 192.168.1.1: bytes=32 time=29ms TTL=64
Reply from 192.168.1.1: bytes=32 time=25ms TTL=64
Reply from 192.168.1.1: bytes=32 time=102ms TTL=64
Reply from 192.168.1.1: bytes=32 time=72ms TTL=64
Reply from 192.168.1.1: bytes=32 time=94ms TTL=64
Reply from 192.168.1.1: bytes=32 time=41ms TTL=64
Reply from 192.168.1.1: bytes=32 time=89ms TTL=64
Reply from 192.168.1.1: bytes=32 time=82ms TTL=64
Reply from 192.168.1.1: bytes=32 time=91ms TTL=64
Reply from 192.168.1.1: bytes=32 time=105ms TTL=64
Reply from 192.168.1.1: bytes=32 time=85ms TTL=64
Reply from 192.168.1.1: bytes=32 time=86ms TTL=64
Reply from 192.168.1.1: bytes=32 time=52ms TTL=64
Reply from 192.168.1.1: bytes=32 time=93ms TTL=64
Reply from 192.168.1.1: bytes=32 time=64ms TTL=64
Reply from 192.168.1.1: bytes=32 time=55ms TTL=64
Reply from 192.168.1.1: bytes=32 time=10ms TTL=64
Packet Loss Test:
I have also run a Wireshark test but i have no idea how to make that info intelligible to me.
I would greatly appreciate anyone's help here and am open to all suggestions.
1 Reply
An Orbi satellite that is 60 ft. distance from the router is not likely to have great performance.
How does the router Attached Devices display the satellite connection. Does it show "5GHz Good"?
