Roger10
Sep 04, 2020Follower
PC Doesn't Detect ORBI RBR750 Wifi
My PC sees every WiFi signal available except the ORBI RBR750. All my other devices see the ORBI signal and connect easily. It should be pretty simple. Any ideas?
- minesweeperAspirant
PC driver may need an update. You can also try disabling 11ax in Orbi and see if it helps.
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Be sure your wifi adapter drivers are updated for the mfr of the wifi adapter.
Good Luck.
