JimmySX
Aug 08, 2023Aspirant
Poor Quality Video MS Teams/Zoom
Hi there, I have installed an Orbi RBK852 last week and had some significant issues with zoom and teams. Over a period of 6 days, I have spoken/called Telstra (ISP) and Netgear multiple times wit...
JimmySX
Aug 09, 2023Aspirant
Additional notes; I found that the Orbi was throttling upload speeds. When connected it was fluctuating between 20mbps upload and 0.10mbps. It was causing issues with that but the issue with zoom and teams is still unknown.
- schumakuAug 10, 2023Guru - Experienced User
Dear JimmySX
Welcome to the Netgear Community!
You won't get the attention requested as you selected ins this legacy device area here..
Requesting a moderator Blanca_O to move this thread to the Orbi Mesh Systems community section.
Regards
-Kurt
- DeaneHornsbyNov 04, 2025Tutor
Hi JimmySX, did you ever get a resolution for this? Ive only just started using RBR850 and RBS850 and have exectly the same issues in 2025 :)
