ryuva
Dec 12, 2025Aspirant
Port forwarding not working on Orbi Router RBR350
Hi all, i have an RBR350 router at home, only router, which is connected to the ONT of the ISP. i have tried setting up the port forwarding 5510 for my NAS, on the router. Settings have been sav...
ryuva
Dear Stephen,
Yes, i use https://canyouseeme.org/. the WAN Ip i see on my router is same as the one i see on https://canyouseeme.org/ as well.
And the WAN IP is not among any of those local ip range.
Dec 12, 2025Guru - Experienced User
ryuva wrote:Yes, i use https://canyouseeme.org/. the WAN Ip i see on my router is same as the one i see on https://canyouseeme.org/ as well.
I'm assuming you mean the Orbi router. If so, then the ONT either is a pure modem or it is in a bridge mode.
If you put the NAS in the Orbi's DMZ (as a test), then is it connecting properly?
If not, you probably should contact your ISP support - they might be blocking the port.
ryuva wrote:Also, i need to use the port 5510, as the synology NAS uses only this port for its Active backup for business feature
Yes, ok. It'd be better if they registered a port (or used one in the unregistered range), but that is not in your control.
