JohnAZ5's avatar
JohnAZ5
Printer Connect
I have a new printer, Epson ET-3958 and an Orbi RBS 760 mesh system.After reading many post, I now know the problem is the printer can only connect at 2.4 but the router wants to connect at 5g.
Last night I tried reducing the power on the 5g to 25%, unpluging the close Orbi and reconnecting the printer.  It worked, then I connectedthe close Orbi and chaged the 5g power to 100%,  This morning the printer was disconnected.
What can I do to keep the printer using the 2.4g and not attempt to reconnect at 5g?
Thanks is advance
John
  • plemans's avatar
    so you can get it to connect, it just doesn't stay connected?
    Did you check with epson?
    Or go into the orbi and set the printer with a reserved IP address?
    • JohnAZ5's avatar
      JohnAZ5
      My mistake, and misleading information from Epson support.  A ethernet cable works great as does when a move a Orbi within 5' of the printer.  I suspect I have a printer with a weak WIFI.
      • StephenB's avatar
        How close is the printer to the satellite?  If it is very close (around a foot), then the Orbi's transmitter could be overloading the printer's receiver.  This is called "Receiver Desensitivation".
        But if this were the cause, then reducing the Orbi signal strength is not a good solution.  The signal strength affects the entire mesh, so there are other consequences - satellites getting a poor backhaul connection to the router, and loss of whole house coverage.
