TrippleP
Feb 22, 2023Aspirant
Printers friendly to Orbi
Could I get a list of printers that work with the Orbi WPA2/WPA3 security? My last 3 printers have been nothing but trouble, showing "offline" when they are online, 100% pass. I've finally pinpointed it down to the security being WPA2-PSK/WPA3-personal. To circumvent this, I actually have to connect the printer to the IoT network, set it only to WPA2-personal, and then every time I need to print something, I need to connect the laptop to the IoT network!
If there are printers that are a little smarter and able to recognize the security settings of the Orbi, I would love to know!
TIA
Do you have the Orbi 9 series system? If so then the mixed mode WPA2 and WPA3 maybe the issue. This would be on the devices Mfr part in having compatibility of there devices that don't support actual WPA3 however WPA2 is supported however some of these devices don't seem to handle mixed mode even though WPA2 is being broadcast. This is something the mfr of these devices needs to handle for there products. Otherwise you'll need to use the IoT network that has the WPA2 only setting as the main network doesn't offer the WPA2 only setting.
NG wouldn't have a list of devices that doesn't support mixed modes. It's kind of a thing that if it works it does, if it doesn't, it doesn't.
- TripplePAspirant
Yes, I do have the Orbi 9 system. my current printer needs WPA2, and my system only has the WPA2-PSK bundled up with WPA3-personal. The printer cannot communicate through WPA3, so even though it is online, and the printer software shows it connected and passes all tests, the other devices in my network see it offline.
So, do you know of any printers that are able to communicate on this mixed mode of security?
I don't.
Can the printer be ethernet connected to the Orbi system?
Which model of Orbi?
Could you please describe more about "showing 'offline' when they are online". Is this on the printer control panel? On the Orbi app? On the Orbi web interface? Are you able to 'ping' the printer?
- TripplePAspirant
On the printer UI it shows printer is connected and passes all tests.
On the orbi app it shows offline, but with a static IP assigned. (for some reason I am not able to sign into the web interface. will troubleshoot this later...right now I need this printer to work!)
On laptop, desktop, phones and tablets, printer shows offline. No communication is possible at all. Not through the smart printer app, not through any program that allows printing. You cannot "choose" the printer, it is grayed out and says "offline"
How does the Orbi app indicate that the printer has a static IP?
My Android Orbi app shows only devices that are connected to the network. Devices that are "offline" do not appear at all.
Would love to see a screen shot of this.
Which specific printer is this? (would like to look at the user manual)
Going out on a limb here, but was this printer working with a different home network before the Orbi 960 was installed?
(and all those devices were printing successfully to the printer with that previous network?)
TrippleP wrote:To circumvent this, I actually have to connect the printer to the IoT network, set it only to WPA2-personal, and then every time I need to print something, I need to connect the laptop to the IoT network!
What is your specific printer make and model that you're having troubles with? What is it's IP address when connected to the IoT network and what is your laptop's IP address when connected to the main network?
Something else is wrong if you need to connect your laptop to the IoT network to print. The 9-series IoT is just a separate radio and any device connected to that radio is connected to your Orbi network, similarly to how it shouldn't matter if your laptop is connected to the RBR or one of the satellites. I configured my 9-series IoT network to only 2.4Ghz to support random older wireless devices, but regardless all of my devices talk to each other just fine.
My Orbi network has been fine for my 3 printers: HP M477fdw, HP M1536dnf, and HP MF420. All printers are connected to my main network set to WPA2/WPA3 mixed-mode setting. I wouldn't expect printers to have a problem with the security setting and instead the 2.4Ghz compatibility issues. For the latter, try setting your IoT network to 2.4Ghz-only and maybe even TKIP/WPA2 security.
I've been out of town, and notice that this topic seems to be unresolved, or......?
- TripplePAspirantCrimpOn,
I would have hoped that there was somewhere a list of printers that work on the WPA3 and WPA2 mixed security. The HP customer service tells me the printer I have only works WPA2… it seems there isn’t one though…
