michaelsam's avatar
michaelsam
Probelems with Router Satellit connection - RBK350
!!! ORBI RBK350 !!! - Category is not available
I am living in a big city in a flat, and there are many flats around with many 2,4Ghz WLAN Connections.
So my Satellit always looses connection.
I realy urgend need a button to set Router to Satellite Connection to use always 5Ghz.
Else i can't use this Model in future and will have to send it back, cause it is unuseable for me !!
So pls integrate such button as soon as possible in your firmware !!
  • CrimpOn's avatar
    CrimpOn
    Yes, Netgear put the 'package' part numbers in the drop down list, but not the router itself.  The default connection between router and satellites is 5G.  This model is a "Dual Band" unit, where the user 5G devices and the backhaul both use the same 5G channel.  The User Manual shows that the 5G channel is set to 157 in NA and PR and to 108 in the rest of the world, including Japan.(see page 130)
    https://www.downloads.netgear.com/files/GDC/RBK352/RBK352_RBK353_UM_EN.pdf
    If the Orbi web interface Attached Devices page shows a satellite connected to the router at 2.4G, that is an indication that the 5G signal between them is not strong enough.  Is it possible to move the satellites a bit closer to the router until the connection changes to 5G on the Attached Devices page?
    • michaelsam's avatar
      michaelsam
      The Problem isn't the users Device, cause it is set to always use the 5Ghz connection in the Driver Properties in Windows.
      Also tried before to use Auto, didn't work also.
      Before the Mesh Routers i had a TP Link Router and an TP Link Extender, and was always connected to the 5Ghz Band and never had problmes with that. But the Extender got broken and like the Router it was also not MIMU able.
      The Problem i have is, that always when the Computer loses Connection to the Internet the Satellite is connected with 2,4 Ghz to the Router.
      Also tried to change position of the Satellite and didn't change anything.
      There are just about 3 meters between Router and Satellite, but there are two big reinforcedconcrete walls. This is the reason why i need this two routers in my 100 sq.m. Flat.
      I know that it would be possible to turn off 2,4Ghz at all, but i have a Printer, which doesn't have that 5Ghz Band.
      The Problem is that always my Kids are affected during school Lessons at home when such problemm apears. So i need as soon as possible a solution for that.
      • CrimpOn's avatar
        CrimpOn
        Does the satellite ever connect to the router at 5G?
        It  could be that two walls reduce the 5G signal so much that the Orbi switches to a 2.4G backhaul.
        Can you experiment with moving the satellite so that the backhaul signal has to penetrate only one wall and the PC connection has to penetrate one wall? (see attached drawing)
        My understanding is that it is not possible to turn off the 2.4G WiFi on Orbi products. Aside from the printer issue, I fear that having no 2.4G WiFi would mean that the satellite will not connect to the router at all.
        Do you remember what the WiFi link was between the TP link router and satellite?  Was it 5G or 2.4G?
