ctdennis
Sep 06, 2020Aspirant
Problem in RBS850 Ethernet backhaul connect to RBR850
It didn't work; tried many times with updated firmware
Works fine when using wireless connection
- Chuck_MMentor
Can you provide more details including model, firmware, any switches in your network, and devices attached?
- ctdennisAspirant
I connected same as discribed, but didn't work.
- Chuck_MMentor
ctdennis wrote:I connected same as discribed, but didn't work.
You are not helping us help you with vague language "Didn't work"
Perhaps you can describe cables... what kind are they? How long are they? Did you put the ends on or were they commercially purchased?
What (if any) troubleshooting steps you may have taken and the results?
Does a laptop or desktop connect when plugged directly into the router?
Does the satellite connect wirelessly when within range?
Is there power to the router?
Is there power to the satellite(s)?
What colors are showing on the sattelite(s)?
