biotecher
Sep 09, 2025Aspirant
Problem with an RBR750P satellite but I have not changed the firmware
I recently (a few months ago) purchased a RBR750P kit from Best Buy that included 2 satellites. Out of the box, the satellites connected fine and worked well. About a week ago I tried rebooting the...
- Sep 17, 2025
I called Netgear and the technician led me through all the steps listed above. Ultimately, he isolated each satellite by having me plug it directly into the router by ethernet. Once that was done, it was discovered that one of the satellites had failed to update the firmware. Everything worked perfectly once the firmware matched all the satellites. I have an RBR750P with 2 satellites. By the way, resetting did NOT fix the problem. Only by examining each satellite individually by ethernet was the technician able to confirm the firmware version. All this happened during a router reboot where the system was probably trying to update the firmware but was interupted.
Sep 09, 2025Guru - Experienced User
You have a RBR750P and a RBS750P?
What FW version is on the RBR?
Tryied downgrading FW on the RBR to see if the RBS will re-connect?
https://www.netgear.com/support/product/rbk752p/#download
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
What channel configurations are currently set on the router?
Try a factory reset on the RBS and RBR and let them auto connect to the RBR before beginning to setup the system using a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- biotecherSep 17, 2025Aspirant
- FURRYe38Sep 17, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - biotecherSep 17, 2025Aspirant
Not sure how to mark as "Solved" but please feel free to do so.
Thanks,
Mark
Your a success. You marked it as such.
Enjoy.
