jln2
May 02, 2026Follower
Problem with satellite
When I use speedtest.net on my laptop beside my main RBR750P router, I get a download speed of ~500 Gbps, which is what I am paying for. At my satellite, 30-40 feet away (two walls) it drops to 1-6 G...
- May 02, 2026
First, internet speed is measured in Megabits per second, i.e. Mbps. No Internet Service Provider (ISP) can deliver 500Gbps speed.
Yes, both the Orbi web interface and the Orbi 'app' will display which devices are connected to the router and which are connected to the satellite.
I would suggest starting with the web interface, described on page 89 of the User Manual
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
This will show the router to satellite connect speed and quality and list all connected devices.
May 04, 2026Guru - Experienced User
Test it with your laptop hardwired into the satellite. That'll tell you if its a backhaul issue such as distance, interference, or something blocking (like metal/cement).
