jacs2macdotcom
Jul 15, 2025Follower
Problems running media player
Modem/WiFi: Sagemcom Pack f@st 3896 v3.3 CHVU
Router/MESH: ORBI 850 router, one satellite
Extra WiFi: Apple Time Capsule
Mediaplayer with IDAGIO and QOBUZ installed for streaming music.
Problem:
When running the media player on the ORBI MESH, respons to the play commands is either very delayed or, more often, there is no response at all. Random clicking on the playlist will sometimes elicit a response, but not always. If I connect to the Sagemcom or Time Capsule WiFi everything works normally. The problems started a few months ago after several trouble free years. Both the media player and the ORBI are up to date and there has not been any recent updates installed. No other problems with the ORBI.
It seems to that the ORBI router has developed a problem to transmit the necessary commands.
Any ideas out there?
1 Reply
What mode is the ISP gateway in? There is a router built in there.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Is IPv6 enabled on the ISP router or Orbi RBR router?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with the Apple Time Capsule turned OFF?
Is this this the only device exhibiting this issue?
Make contact with the Mfr of the streaming services for additional help and infomormation regarding there product as well.
