donawalt's avatar
donawalt
Hero - Experienced User
Jul 16, 2023
Procedure for Factory reset of RBS850
Hi all, I am just doing some maintenance on my RBR850/RBS850s (2) system, to factory reset them since it's been a long time. Yesterday I did a factory reset on the router and manually re-entered any settings I needed,. All works fine.
Today I want to factory reset my 2 RBS850 satellites, one at a time. I like having a solid procedure to follow, and I couldn't find one for satellites, which I presume are much simpler than factory reset-setup of a router (I have a good procedure for that).
So - is my procedure for a reset of an RBS850 as simple as:
- This Satellite has Ethernet backhaul. Temporarily move it near the router using wireless only. Plug it in.
- Press paper clip in the reset hole until power LED blinks amber (~15 seconds).
- After that, satellite front display should eventually turn solid white (~2 minutes).
- Go to the router admin web page,  Go to Basic tab, then Add Orbi Satellite and follow directions in setup wizard (press sync button on satellite, then press sync button on admin web page).
- After sync is successful, power down satellite and move it to its normal locations, connect to Ethernet/back haul, power up.
- Wait for front display to turn Solid Blue. when it does, satellite is connected and sync'd.
That should be it, right? No worries about settings or anything, like with the router? Any advice as to other steps to take, to make this reliable/smooth?
Thanks!
  • Did you try the 2nd RBS with the 1st RBS turned OFF?
    Try selecting Generate Backhaul Password on the RBRs web page Under Advanced Tab/Advanced Settings/Wireless Settings. Then press the sync button on the RBS then on the RBR or walk thru the Add Satellite feature on the RBRs web UI.
  • FURRYe38's avatar
    The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS.
    Otherwise, great process for FR the RBS. Works well.
    • donawalt's avatar
      donawalt
      Worked like a champ. The only additions/mods I made were (1) the time waiting for the solid white light is closer to 5 minutes and (2) After I pressed the reset hole and the amber light blinked, I went to the admin web page, Attached Devices list, and Removed that Satellite from the list (showing as Disconnected). It got re-added once it sync'd up again.  (3) Once all done, change the Satellite name in Attached Devices list if need be.
      • donawalt's avatar
        donawalt
        Hmm. Not so good with second RBS850. No matter what I do, I press the reset hole, I get the amber blinking light, but it always ends up blue on the front, and connected to the router again! It never goes to solid white. I have tried all kinds of combinaitons of power off/on, manual sync with router then reset  it keeps coming up with blue light, sync status "Good". Why won't it factory reset? Is there another way to factory reset a satellite?
        EDIT/UPDATE: I brought up the router admin web page, and there the satellite's name was reset to the default "Orbi Satellite-1" or something similar.
  • donawalt's avatar
    donawalt
    The only thing I would add in further testing, is if there are other RBSs online, power them OFF prior to the factory reset of each RBS. There should only be one RBS powered up, their current one being factory reset, at a time. I found problems with getting the factory reset (solid white) coming up with other RBSs online - an RBS would keep coming up BLUE (meaning connected and sync'd.)
