nk1975's avatar
nk1975
Questions about wired backhaul
Hello
I recently bought the Orbi AX6000 rbk852 2 pack
and am pretty happy with it.
However I still get a few weak signals around my house. I have the router upstairs
and the satilite in the basement directly wired into the gaming system for the kids.
I am considering buying another satelite so I can set up the wired backhaul.
Will that give me any additional benifit?
Thanks!
  • FURRYe38's avatar
    Sometimes wired vs wirelss is more stable than wireless or if you want a RBS out a fare distance from the RBR, the RBS won't connect wirelessly so wired RBS can be setup for this configuration. The only draw back is that the back haul speed is limited to 1000Mbos vs 2400Mbps that the Orbi AX provides wirelessly. 1000Mpbs wired speeds are still good and have good performances.
    • nk1975's avatar
      nk1975
      Ok, thanks!
      So I can still have my satelite in the basement wired into the gaming system,
      and buy the 3rd satalite and do the wired backhaul into the main router?
      That's what I want to do.
      I am fine with the speeds, as the wireless speeds on 5g and kinda all over the place.
      Thanks!
