MrJamison
Feb 20, 2024Aspirant
Random ghost satellite driving me mad.
I recently upgraded my home internet to 2GB. After doing so, I purchased Netgear multi-gig unmanaged switches for the house. In order to take advantage of the higher speed, I direct connected one of ...
Feb 20, 2024Guru - Experienced User
Got a screen capture of this?
Is this the Orbi 960 series you have tagged?
What is the model #'s of these switches you have in use?
Did you first synce the RBS to the RBR before ethernet connecting them?
If you bring the RBS near or in same room as the RBR and ethernet connect them there, does this ghost satellite appear still?
3500 sq feet the RBR and just one RBS should work however depending on building materials, two maybe needed with lowering the power on the RBR to say 50% and check.
MrJamison
Got a screen capture of this? Yes. Notice the ghost has no hardware version, no firmware version, and no serial number.
- This is one router, and three satellites. (RBRE960 + (3) RBSE960's)
- NETGEAR 5-Port Multi-Gigabit Ethernet Unmanaged Network Switch (MS105) - with 5 x 1G/2.5G
- Yes, it was synced showing "GOOD" before it was wired in.
- YES. Note the ghost sat ONLY appears when it is connected to 2.5GB switch. I have a second sat wired in on a 1GB switch and this issue is not present on that one. Only on the 2.5GB switch.
- I have not adjusted the power settings, so they will be at default. I am not sure I understand your point, so i will have to look into it. My home is beyond insulated and I have had wireless signal issues through three different WiFi networks since we moved in.
- V6.3.7.10 on everything.
- FURRYe38Feb 20, 2024Guru - Experienced User
So if you take the MS model switch out of the mix does the ghost RBS disappear?
CAT6A STP is recommended.
Your behind on FW as well:
Sounds like a issue being caused by this one particular model switch. You happen to have a spare 1Gb non managed switch to put in the MS switches place to check this?- MrJamisonFeb 20, 2024Aspirant
I check for updates every time I log into it, including last night. So they report no update needed. I just checked again, and the same thing. So I guess I have to update them manually now? They used to auto update. That is stupid if I have to do it one by one manually.
I thought the same thing about the switch, so I bought two more 2.5GB switches a few days ago from TP Link to try, and swapped the main one out in the closet, and the one the sat with the ghost is connected to, and the ghost was still there even after a reboot and a sync.
Yes. Some FW updated have to be manually updated.
If you do, RBS first, then RBR lastly.
Lets try a FW update...
