Smugear
Dec 01, 2025Guide
random loss of wifi
Hi everyone, I have one RBR750 and 2 RBS750. I am working from home and my son is playing video games, so none of us like it when wifi suddenly drops and then a few minutes later the satellite blink...
- Dec 01, 2025
Concerete and steel will be problematic at best for any wireless system.
Lets turn OFF one of the RBS.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Smugear
Dec 01, 2025Guide
Due to concrete walls, the WiFi signal is too weak for my home office on the opposite side of the house from the router. The satellite solves that… until WiFi drops off
Dec 01, 2025Guru - Experienced User
Then the concrete matierials maybe your cause here. No FW version will help with this. Concerete and steel will be problematic at best for any wireless system.
Are RBS wireless connected or ethernet connected? If wireless you may need to get the RBS ethernet connected or at least one of them. Might look into some power line adapters to help here.
