Stefan3189
Mar 10, 2026Aspirant
RB760 cable upload speed capped at 100mbsp
If I connect my laptop through a cable to my orbi, the download speed is correct at 1gbps, but my upload speed is capped at 100mbps. If I unplug my orbi and connect my laptop directly to the interne...
Stefan3189
Mar 11, 2026Aspirant
Yes, that's the case. Download is now 1063 mbps and upload 109 mbps
The WAN port shows 1000M/Full
I will get a switch tomorrow and try to connect it in between my orbi and laptop
Mar 11, 2026Guru - Experienced User
What configuration were you using for this result?
Stefan3189 wrote:Yes, that's the case. Download is now 1063 mbps and upload 109 mbps
