philipmarker
Jun 22, 2022Aspirant
RBK 753 - one satelitte reboots often
Around noon danish time one of my 2 satelittes often reboots (blinking white). Normally this satelittes connection to the router is OK, however sometimes it is yellow (fair). Have inserted th...
Jun 22, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- philipmarkerJun 23, 2022Aspirant
Firmware version is V4.6.5.14_2.0.54
Internet providers modem is a Sagemcom and I have a fiber line with 1000/500Mbs.
Size of home is 250m2 and distance between router and each of the 2 satelittes is 6-10 meters. The one malfunctioning/rebooting is only 6 meters away from router, however with 2 concrete walls in between - this one does also from time to time show a yellow light (which I guess means that connetion is not good but fair)
Using auto on both frequences and do NOT have a fixed IP-adress.
From beginning the Orbi-router was connected to Sagemcom via cable, however with longer distance from the router. Same problem with reboots and connection-quality with satellite was poor. Now the router is placed more central, however connected via a powerline adaptor that has reduced the speed from 1000mbs to approx 150mbs.
Apart from changing fra auto channel to fixed, could it also help to have fixed IP adress and cable connect the router again (more speed)
Can I actually link the router and satelitte with a cable and improve the connetion (If the other options does not help)
The log does not show the reboot - can this not be seen anywhere ?
- FURRYe38Jun 23, 2022Guru - Experienced User
I recommend that you update the RBS first to v.2 FW then the RBR lastly:
Bring them to same room or near the RBR before updating and update FW using the RBS web page to send the FW file too.
I would set up a IP address RESERVATION for both RBS after FW has been updated on the system.
At routerIPAddress/debug.htm and look at the System Uptime section.
- FURRYe38Jun 29, 2022Guru - Experienced User
Any progress on this?
