tucsontico
Oct 28, 2025Virtuoso
RBK 853 5gHz Wireless Backhaul Issues
About 30 days ago, my otherwise rock-solid Orbi 850 system (RBR + 2 RBS) began to slow way down. After some troubleshooting, I noticed the backhaul was using 2.4 gHz, not the dedicated 5 gHz band and...
- Nov 03, 2025
Refurbished RBR850 arrived yesterday. Initialized it and replaced my old RBR with refurb about 1 hour ago. Used backup config file to set up refurb and re-synced sats. After about 10-15 minutes settling time the system came back to daisy-chain topology. 5 gHz backhaul (see screenshot) is working and speeds throughout property are back to historical numbers. (Over 3X faster than when 5 ghz backhaul stopped working).
Obviously, my original RBR had some sort of tx/rx problem in 5 gHz band. All is good...for now!
CrimpOn
Oct 28, 2025Guru - Experienced User
As StephenB suggested, a screen shot of the satellite portion (top) of the Attached Devices web page would be helpful.
For example, the Daisy Chain configuration may have been affected by the closer satellite no longer having a 5GHz backhaul connection.
tucsontico
Here's the requested screenshot (redacted):
