wfox
Oct 30, 2023Aspirant
RBK352 AX1800 (RBS350 Satellite) Power Issues
A few months back, one of our (RBS350) Orbi satellites turned off and refused to turn back on. It had been working well for nearly 2 years. The LED on the back of the unit by the power socket no lon...
- Oct 30, 2023
If you swapped power supplies and the one RBS won't turn on then it's probably busted and needs replacing.
I recommend getting on places like amazon or shopgoodwill and look for replacement RBS350s.
One can also connect EX series extenders, i.e. EX7500, 7000, 7700 or 8000 series.
Oct 30, 2023Guru - Experienced User
wfox
I assumed as much, but it was worth asking! Thanks for responding 🙂
I also had no idea the EXs would talk to an RBR350. I'll check that out, thanks.
