Imbset
Mar 05, 2022Guide
RBK353 drops internet every 20-40 minutes
Morning, Yesterday I’ve got this set delivered to me as my prev. Network was getting a little outdated. Followed the out of the box installation and works great. However, for some odd reason, th...
- Mar 13, 2022A week after making this change;
Technicolor router set from Bridge to Router mode and setting up the DMZ, I’ve had zero disconnects and solved my problem
Much appreciated for the support!!
Mar 07, 2022Guru - Experienced User
Hope if works for you!
If it does, you can mark it solved to help others with this issue.
(please it keeps others from trying to fix an already fixed issue)
Imbset
Mar 13, 2022Guide
- plemansMar 13, 2022Guru - Experienced User
Glad its working!
Sad to see how many ISP devices passthrough function has issues.
