Bertvds's avatar
Bertvds
RBK353 (RBR350 / RBS350) unstable wireless backhaul
Anone else suffering from unstable wireless backhaul on RBK353 ?
- Symptoms: teams calls freeze up for 2-10 seconds, several times per day, while the satellites starts blinking and resynchronizes.  And every now and then (+/- weekly) a device is needed.
- What did I try to fix it ? move satellites closer, move satellite further away. Work with only 1 satellite (iso 2).  Lower signal strength on 2,4 Ghz.  Lower sgnal strength on 5 Ghz.  Fixed channel on 2,4 Ghz (cannot choose on 5 Ghz).  Short or long preambule, ... and many combinations of above.
- Only stable working solution found so far: connect router & satellites via ethernet cable, and it works like a charm ... but the reason for buying this setup was also to not have to put cables everywhere...  even with a powerline in between it works much more stable than with the satellite over wireless backhaul.
Feels like a waste of money.  I was so fed up with it, that I am now using only the RBR350 as router, the satellites are put away, and a simple wifi extender is used to connect an ethernet-only device, and to extend the network with acceptable speed.
Anyone else suffering from this ? bright ideas ?
tx - rgds, Bert
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    Is Armor or IPv6 enabled?
    Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    • Bertvds's avatar
      Bertvds
      Hi,
      Thanks for your response – below you find my feedback on your suggestions.  a
      Your suggestions were not new to me (had seen them before already) and what was possible had been tested already.
      The problem is really in the wireless backhaul.
      • When using the RBR alone (with the satellites disconnected), the system is fast and stable.
      • With the RBR & 2x RBS connencted through powerline adapters, the system is slower but stable enough.
      • With the RBR & 2x RBS through wireless backhaul, it is giving a few interruptions per day (sometimes more, sometimes less). Only noticeable when doing calls, but that is unfortunately a major part of my working day.  Superfast, but with those interrupts making it really unacceptable for my use.
      Below the answers:
      • What Firmware version is currently loaded? V4.4.0.10_2.10.63
      - What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? > – Belgian operator TELENET – docsis 3.0 modem
      • What is the size of your home? Sq Ft? > About 1800 sq ft, over 3 floors.  Seperate house with neighbours around.
      - What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. – > anything between 20 and 50 feet was tried.
      • What channels are you using? Auto? Try Auto and 48 on 5Ghz.
      • Auto was tried, and on this model there is no option to change thannel on 5 Ghz manually, unfortunately.
      • Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.  > These main channels were all tried for 2.4 Ghz, but as mentioned no option to choose with 5 Ghz
      • - Any Wifi Neighbors near by? If so, how many? > Yes there are about 8 neighbouring wifi’s.  Channels were scanned, strongest are the orbi’s channels.
      • Set 20/40Mhz Coexistence to 40Mhz only.  > coexistence has been tested “turned on” and “turned off”
      • Set CTS to 2347. > CTS is not something that can be chosen in the management screen unfortunately.  It has been tested with short and long preamble, with no success.
      • Save settings and reboot the router and satellite(s). > tried that several times
      • Under Advanced Tab/Advanced Settings/Wireless Settings - Is Armor or IPv6 enabled?  > no, is being used in AP mode without Armor.
      tx
      rgds, Bert
      • FURRYe38's avatar
        I would reach out to NG support and ask for a beta build of FW. I've seen other 3 series users posting about problems and was able to contact NG support and was given new FW to try which seems to have solved some of these problems.
        https://my.netgear.com/support/contact.aspx
