Isahar
Jun 30, 2024Aspirant
RBK652 and RBR50
I have been using the RBR50 mesh system for 7 years, and it has been amazing.
Now, I have purchased a new RBK652 system, which includes one satellite.
Is there a way to integrate the RBR50 satellite into the RBK652 system?
Where can I register my new system?
No. They don't integrate.
You can use it separate if you'd like. Just make sure to use a separate ssid and have the wifi on different channels to prevent interference. Put the 2nd system in access point mode to prevent a double nat
- IsaharAspirantWhat about try pairing your RBR50 satellite with the RBK652 system as a main router?
They're not compatible.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
