Russjefferies
Jul 27, 2021Aspirant
Rbk750 and rbs750
Guys looking for 2 extra satellites for my orbi setup, are the RBK750 and RBS750 the same thing?
also, I have the rbr750 with 2 satellites can I add an extra 2?
cheers in advance
Any RB(K)it mean that there is 1 RBR### router and 1 or more RBS### satellite included in the box set. So yes any RBS750 from a RBK7 series kit will work with a RBR750.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡- RussjefferiesAspirant
Thanks for the swift reply, so I can add 2 extra satellites cool.
the main reason for asking the difference is I was thinking of buy 2 of these, but wasn't 100% they were satellites, it says they are in the description but the K in Rbk threw me
Just be aware that the RBR can not operate like a RBS. It only supports router mode or ethernet connected AP mode that would be connected to a host router upstream from it and would not integrate into another Orbi mesh system.
