JimTurkey
Sep 26, 2021Guide
RBK752 & U-Verse. BGW210
So I think I hooked everything up correctly. But something isn't correct as I cannot watch U-Verse TV. The internet seems to work fine but U-Verse freezes about 10 seconds of viewing. Resetting the receiver does nothing.
Just to confirm, I did the following things:
- Firewall. > Set IP Passthrough (set to Passthrough and then selected DHCPS-fixed.
- Packed Filter > (Turned them all off)
- Turned off Wi-Fi for both 2.4Ghz and 5Ghz
- Firewall > Firewall Advanced > (turned all options to Off)
Then, other than ethernet cable from the BGW210 to the RBK752, all others are attached to the RBK752.
And just to check, I reversed all of these steps and removed the Orbi from the setup. So settings were returned to "normal" and ethernet cables were plugged into the BGW210. And U-Verse works fine!
Please help!!
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- thanks so much for the links!
one question, though … with all of the features being disabled in AP Mode, what is/are the advantage of AP Mode?- FURRYe38Guru - Experienced User
Avoid hassles of ISPs modems that may not work right with the RBR In router mode.
IF the RBR is crashing the ISP modem, possible some thing is going on at the modem level as well.
