nathan_84's avatar
nathan_84
RBK752 satellite restarts quite often in a day
I am using Mesh AX4200 WiFi 6 (Up to 4.2Gbps) (RBK752-100EUS) with one router + one satellite.
Recently from 2 days back, my satellite restarts automatically (white light blinks and blue light comes and all light off), for a while it works and again it repeats in a hour.
What would be the probable reason?
Anything to be checked?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    • nathan_84's avatar
      nathan_84
      Firmware: v4.6.3.7
      The internet provider provides a RJ45 cable input which is connected directly to the router.
      Size of home: 2 floors - each floor is 800 sqft- router is place in ground floor and satellite in first floor
      There are two neighbours
      It was working perfectly for 3 months since I bought, but thus restart occurs from this weekend.
      I did tried rebooting router twice yesterday and today, but didn't helped.
