philipmarker's avatar
philipmarker
RBK753 AX4200 - Router placement & daisy chain
Does this model support daisy chain ? When trying to find activate/deactivate box under admin log in (advanced wifi-setting), it does not pop up ?.
Have problem with connection to one of the satelittes and moving the router more cental in the house is quite a hazzle with cabling. So was looking to see if an extra satelitte and using daisy chain could be an alternative solution. The house is quite "long"
